Foam For Double Oven Cavity - Insulation - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 10:25 AM   #1
Foam for double oven cavity
I am installing a double oven and the manufacturer says it can hit 200 degrees F in the oven cavity. I don't want to vent the heat since then the oven will just have to work harder to maintain temperatures. So, I'd like to put up foam panels to both protect the surrounding walls and make the oven's job easier.
200 degrees isn't a whole lot in the grand scheme, so does anyone know what may work here?
gdiviney is offline   Reply With Quote
Old 06-02-2013, 11:08 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,244
Wouldn't bother with foam.
Use a non-combustible like Roxul.
Old 06-02-2013, 12:14 PM   #3
Thanks! Its king of thick, but I suppose I could compress it. I only have about 1 inch per side for the solution
B-12 Chemtool versus SeaFoam DrHicks Automotive Repairs 16 10-01-2012 08:57 PM
Built-In (back) Oven Clearance for NM Cable? dcarpen23 Electrical 4 08-29-2011 11:29 PM
Roper Electric Oven Range Problem mcnutty Appliances 6 07-05-2011 05:32 PM
Foam and Elastomeric coats over existing BUR ???? sunguy65 Roofing/Siding 2 02-25-2011 12:48 PM
Foam board and electrical boxes Master Brian Electrical 5 11-21-2010 07:03 PM
