Foam Board Necessary? - Insulation - DIY Chatroom Home Improvement Forum
Old 07-25-2013, 02:05 PM   #1
Foam board necessary?
Looking to insulate and drywall the basement bathroom this weekend. The wall is framed out about 3" from the block foundation which is where the supply lines and vent lines are. Do I need to put foam board up along the block wall or will the empty space not create that much of a cold spot?
TIA
Leroy
lk00331 is offline   Reply With Quote
Old 07-25-2013, 02:10 PM   #2
Rewards Points: 6,652
Depends on where you live.
Old 07-25-2013, 02:11 PM   #3
Notheast iowa. Warm humid summers and cold winters.
Old 07-25-2013, 02:15 PM   #4
No different from te rest of the Midwest. Yes, you need either Foamboard, or have closed cell foam sprayed after framing the wall, and running all wiring, for both low voltage and any 120 or 240 vAC.
The Following User Says Thank You to gregzoll For This Useful Post:
lk00331 (07-25-2013)
Old 07-25-2013, 02:17 PM   #5
looks like I will be adding foamboard to the list.
thanks!
Old 07-26-2013, 11:39 PM   #6
Registered User
Rewards Points: 526
The empty space will give convective loops behind the batt insulation; https://docs.google.com/viewer?a=v&q...fHFsk1RrK9G2HQ
Foamboard is not the only system, just the safest, especially if walls are not perfectly dry all the time; http://www.buildingfoundation.umn.ed...em/default.htm
http://www.buildingfoundation.umn.edu/MainPage.htm
And from up North; http://www.buildingscience.com/docum...Insulation.pdf
The testing; http://www.google.com/url?sa=t&rct=j...3dQqtw&cad=rja
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
lk00331 (07-27-2013)
Condensation On Foam board in basement tlh123 Building & Construction 1 02-12-2013 01:49 PM
Foam board over batts juststarted Insulation 3 12-13-2011 12:12 PM
Installing foam board around windows ? Arky217 Windows and Doors 3 09-12-2011 04:13 PM
foam board between joists fubar79 General DIY Discussions 17 10-05-2010 09:38 PM
House wrap over insulating foam board or under?? getn2old Building & Construction 7 07-28-2010 10:53 PM
