-   Insulation (http://www.diychatroom.com/f103/)
-   -   Foam board necessary? (http://www.diychatroom.com/f103/foam-board-necessary-184237/)
lk00331 07-25-2013 02:05 PM
Looking to insulate and drywall the basement bathroom this weekend. The wall is framed out about 3" from the block foundation which is where the supply lines and vent lines are. Do I need to put foam board up along the block wall or will the empty space not create that much of a cold spot?
TIA
Leroy
gregzoll 07-25-2013 02:10 PM
Depends on where you live.
lk00331 07-25-2013 02:11 PM
Notheast iowa. Warm humid summers and cold winters.
gregzoll 07-25-2013 02:15 PM
No different from te rest of the Midwest. Yes, you need either Foamboard, or have closed cell foam sprayed after framing the wall, and running all wiring, for both low voltage and any 120 or 240 vAC.
lk00331 07-25-2013 02:17 PM
looks like I will be adding foamboard to the list.
thanks!
Gary in WA 07-26-2013 11:39 PM
The empty space will give convective loops behind the batt insulation; https://docs.google.com/viewer?a=v&q...fHFsk1RrK9G2HQ
Foamboard is not the only system, just the safest, especially if walls are not perfectly dry all the time; http://www.buildingfoundation.umn.ed...em/default.htm
http://www.buildingfoundation.umn.edu/MainPage.htm
And from up North; http://www.buildingscience.com/docum...Insulation.pdf
The testing; http://www.google.com/url?sa=t&rct=j...3dQqtw&cad=rja
Gary
