Foam Board Install - Insulation - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 04:52 PM   #1
foam board install
I am installing foamboard on concrete walls in the basement, and wanted to know after I seal the concrete do just liquidnails it onto the walls or do I still need to fur them out
moose73 is offline   Reply With Quote
Old 01-25-2012, 04:59 PM   #2
AGWhitehouse's Avatar
don't need to seal the concrete if you're putting up foam. Use the adhesive that is made for the application, it says it right on the tube.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 01-26-2012, 01:21 AM   #3
Rewards Points: 1,092
I'd add to that: Assuming your walls are dry all the time. If not, fix the outside first.
The Following User Says Thank You to jklingel For This Useful Post:
AGWhitehouse (01-26-2012)
vapor barrier under foam board basement? alecmcmahon Flooring 1 01-14-2012 03:17 PM
R-Value Thickness foam board in basement floors/walls alecmcmahon Insulation 6 01-10-2012 03:38 PM
Foam board over batts juststarted Insulation 3 12-13-2011 01:12 PM
Concrete over foam board Mudball Building & Construction 16 01-11-2010 11:03 PM
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 09:18 AM
