-   Insulation (http://www.diychatroom.com/f103/)
-   -   foam board install (http://www.diychatroom.com/f103/foam-board-install-131392/)
moose73 01-25-2012 03:52 PM
foam board install
I am installing foamboard on concrete walls in the basement, and wanted to know after I seal the concrete do just liquidnails it onto the walls or do I still need to fur them out
AGWhitehouse 01-25-2012 03:59 PM
don't need to seal the concrete if you're putting up foam. Use the adhesive that is made for the application, it says it right on the tube.
jklingel 01-26-2012 12:21 AM
I'd add to that: Assuming your walls are dry all the time. If not, fix the outside first.
