-   Insulation (http://www.diychatroom.com/f103/)
-   -   Foam around heat vents (http://www.diychatroom.com/f103/foam-around-heat-vents-170079/)
brockmiera 01-25-2013 09:39 AM
So I am in the process of putting up XPS in my basement, cutting small pieces and putting them in the joist cavaty's against my sill plate (I think thats what its called) Anyway I was reading the can of great stuff that I am using to seal up around the foam and it says it is very flammable.
To that I ask. Can I use it to seal up around the heat ducts that are going upstairs?
I can post a few pictures later today.
joecaption 01-25-2013 09:44 AM
Yes you can but it's more often done with foil tape or mastic.
A heating duct at the end of the run is never going to get hot enough to cause it to burn.
brockmiera 01-25-2013 10:01 AM
I really want to seal up around the floor and the heat duct to minimize the sound transfer that happens at that point. There is a good 1/2" between the floor cut out and the duct work.
I can go and get whatever I need to make it right.
HomeSealed 01-25-2013 10:22 AM
Foam is fine there. You just can't use it around chimneys etc. (the exhaust side of combustion appliances)
brockmiera 01-25-2013 11:30 AM
Sounds good. Thanks!
