Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 04-21-2011, 07:13 AM   #1
Floor joist insulation over basement.
I have a two story house over a block wall basement with a two car garage. I'm going to insulate the 2x10 for noise and temp but am not sure it I need to use a vapor barrier. The first floor is mostly T&G wood over 3/4 plywood. I do plan to finish part of the basement eventually.
rjheard is offline   Reply With Quote
Old 04-21-2011, 05:53 PM   #2
Windows & Remodeling
HomeSealed's Avatar
You basement is conditioned airspace. A vapor barrier in that app would not be appropriate, and you won't see any energy benefit either. If sound is your main concern, then go for it, just use a material that will be well-suited for that purpose. For energy-savings, you'll want to insulate the exterior walls of the basement. This is a very popular topic and there are a ton of threads, links, etc with good info. I'd also recommend www.buildingscience.com for some excellent info on the subject.
HomeSealed is offline   Reply With Quote
Old 04-22-2011, 12:59 AM   #3
Moderator
Use Roxul insulation rather than f.g. for sound. The 3/4" plywood has about the same moisture stopping abilities as the Kraft faced insulation. They probably already installed tar paper under the hardwood flooring for squeaks and moisture protection. Insulate the rim joists with foam board, air sealing afterward; http://www.buildingscience.com/docum...m-at-rim-joist
Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
Basement insulation / vapor barrier questions deepstuff Building & Construction 16 02-09-2012 10:11 AM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 06:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 05:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
