Floor Joist Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 10-17-2013, 04:18 PM   #1
Rewards Points: 225
floor joist insulation
Hi folks,
I was wondering what kind of insulation you'd recommend - if any at all - for the floor joists that are exposed in my basement.
in the winter, it gets pretty cold out here in PA and I'd like to do my best to keep the cold in the basement and the warmth up in the living spaces.
Here's some photos of my floor joists in my basement:
andrewjs18 is offline   Reply With Quote
Old 10-17-2013, 10:20 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,570
No need to insulated between conditioned floors.
Start researching on air sealing and insulation. That is where you are going to save money.
Old 10-23-2013, 11:32 PM   #3
Registered User
Rewards Points: 526
Right now the heat from the room above helps warm the basement, insulating there may cause your water lines to freeze. This depends on the amount of heat in the basement from the boiler ? and other HVAC equipment. I'd air seal all wiring/plumbing holes with fire-rated foam in the floor above, caulk the windows, etc.; http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
This will help stop the stack effect to the attic; http://www.wag-aic.org/1999/WAG_99_baker.pdf
Canned foam/Thermax the rims; http://www.buildingscience.com/docum...l_seal_rev.pdf
If looking for a warmer floor- full speed ahead;http://www.buildingscience.com/docum...n-crawlspaces/
Gary
Old 10-23-2013, 11:42 PM   #4
Rewards Points: 6,652
None, unless you plan on finishing it for a home theater down there, or home office, and want to keep the upstairs noise down, from disturbing the person down there.
If you are having an issue with a cold house, then you need to direct your attention to sealing around Windows, Doors, electrical outlets, air sealing up into the attic space, insulating the attic, insulating around the perimeter of the basement Joist bays on all four sides.
You also need to introduce conditioned air into the basement, to help keep the upstairs also warm. That means a/c during the Summer if you have Central Air, and heat during the Winter, even if it only brings it up to say 59, it is better then going down there and finding burst pipes, because it got below 45.
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 06:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
