Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-25-2012, 07:39 AM   #1
Floor insulation
Here's my situation which I hope someone has a solution for. My house is built on a full basement. Half of the basement will be an uninsulated garage. The floor above the garage will be insulated with roll fiberglass. Since the house floor sheathing is down I can't put the insulation in from the top so that the vapor barrier is facing the warm side of the house. How do I handle the vapor barrier situation? Thanks.
stevebei is offline   Reply With Quote
Old 01-25-2012, 09:56 AM   #2
Floor insulation
One option, albeit time consuming, would be to purchase a vapor barrier such as felt paper, and install it between the joists from below. Using an unfaced insulation below the vapor barrier should then solve your problem. To hang, look into getting insulation hangers.
AgBuilder is offline   Reply With Quote
Old 01-25-2012, 06:34 PM   #3
Floor insulation
see above. Also have done strips of poly between joists against subfloor and acoustical sealant caulked to joists
mae-ling is offline   Reply With Quote
Old 01-27-2012, 10:14 PM   #4
Moderator
Floor insulation
Felt paper (5-25 perms) is way more open than plywood/OSB (0.75 perms) sub-flooring so it wouldn't do much here. Add 5/8" fire code (Type X) drywall to fig. 7: http://www.buildingscience.com/docum...n-crawlspaces/
And, welcome to the forums!
Gary
Clothes taking longer to dry?
