Fireproof Cover Over Foam Sheets.Is There Anything Besides Drywall? - Insulation - DIY Chatroom Home Improvement Forum
Old 03-23-2014, 06:27 PM   #1
Fireproof cover over foam sheets.Is there anything besides drywall?
Gerry Hendry is offline   Reply With Quote
Old 03-23-2014, 06:29 PM   #2
Rewards Points: 1,010
Your post makes no sense
Anti-wingnut is offline   Reply With Quote
The Following User Says Thank You to Anti-wingnut For This Useful Post:
gregzoll (03-23-2014)
Old 03-23-2014, 06:30 PM   #3
Rewards Points: 13,994
Why not drywall?
What it your coving with foam?
Old 03-23-2014, 06:32 PM   #4
All I see is a google map
Old 03-23-2014, 06:32 PM   #5
Cathedral ceiling being covered with foam sheets inside.The final inside covering should be fireproof.
Old 03-23-2014, 06:38 PM   #6
Going to have to use 5/8 fire code drywall.
Just how do you plan on adding this foam and be able to add something over it?
What's got to hold it up?
Old 03-23-2014, 06:40 PM   #7
Foam to screwed in place then 1x2strapping to hold the drywall.
Old 03-23-2014, 06:53 PM   #8
What is the occupancy of the structure? A SFR?
Old 03-23-2014, 07:15 PM   #9
Ever seen what happens to a 1 X 2 when you run a row of screws in it?
It splits right down the middle.
Old 03-23-2014, 09:58 PM   #10
Good to know.That's why I posted.
Old 03-23-2014, 10:14 PM   #11
#1 No one know where you are on the planet because there's no location in your profile.
Questions like this workout better if you would go to quick links and edit your profile to add your location.
The right way in my option would be to remove the drywall that's there now, add baffles so there could be air flow from the soffits to a ridge vent.
Shim out the rafters to fit the needed room for the required insulation, insulate, and sheetrock.
Just guessing here, there's no pictures of your home, no location.
Old 03-23-2014, 10:44 PM   #12
He lives on Doran Rd, halfway between Gill Rd and Bayfield Street
Old 03-24-2014, 06:41 AM   #13
I'd like to thank all for your comments .I'ts been fun!
Old 03-24-2014, 09:14 PM   #14
Rewards Points: 236
Midhurst, ON Canada
Fix'n it is offline   Reply With Quote
Concrete, Foam Board then Drywall benleef Remodeling 4 01-18-2013 05:36 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
injecting spray foam insulation into a 2' cut out section of basement drywall. spuds65 Insulation 5 09-15-2011 10:07 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
