Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 12-13-2012, 09:33 PM   #1
Fireplace popout cold air
I have a newer home(2010) and it has a natural gas direct vent fireplace installed in a pop out/cantilever.
There has always been a cold draft coming through the bottom of the fireplace in the living space. Down in the basement there is a large cut out for the gas line that runs into the fireplace from underneath. There is a obvious cold draft pouring in this hole into the basement(and leaking into the FP) and there the temperature reading is only a few degrees above exterior temperature. If I stick my arm into this cavity I cannot feel any insulation.
Any suggestions how to approach this?
n0c7 is offline   Reply With Quote
Old 12-14-2012, 08:00 AM   #2
Exterior Construction
Windows on Wash's Avatar
How much demo to you want to do?
The reality is that the fireplace was set before the home was insulated and there is usually no insulation and zero attention to the air barrier details in those builder's grade fireplace installs.
If you have vinyl siding on the exterior, remove it all, pull the sheathing off, insulated the cavity with Roxul, seal all the gaps, and put it back together.
That is easier than interior demo and the vinyl siding (if that is what you have) can easily be re-used.
Be sure to remove it when it is relatively warm so it will bend as compared to crack.
Old 12-14-2012, 10:00 AM   #3
Got a picture?
That bump out was suppot to be insulated and covered with plywood on the underside.
Old 12-14-2012, 10:40 AM   #4
I'm pretty handy, I've been avoiding this since the house was still under warranty but I cannot convince the builder to do the demo. It is vinyl siding and aluminum fascia on the underside(vented style though, not sure if I should change this). I'm building my garage this summer if everything goes as planned so I'll have some spare materials incase anything breaks.
I believe my fireplace is a 0 tolerance model. Should I just insulate every gap possible with Roxul or should I try to have some warm basement air feed the cavity as well? Any vapor barrier needed?
Old 12-14-2012, 10:43 AM   #5
Originally Posted by joecaption View Post
Got a picture?
I can take some when I get home to show which cut out I'm talking about.
Old 12-14-2012, 02:28 PM   #6
Got a picture?
+1
Pulling that down and spray foaming it is a pretty good option but access is usually a PITB because it is so close to the ground.
If you are handy, you can do it.
I would worry about the vapor barrier if you get it zipped up tightly.
Old 12-14-2012, 03:18 PM   #7
+1
The builder did attempt to spray foam from the inside but that actually made things worse as now all the cold air was convecting through the bottom of the fireplace compared to some of the warm basement air countering it.
I'm assuming you mean you wouldn't vs would worry?
Old 12-14-2012, 05:30 PM   #8
Some pictures sure would help.
Old 12-14-2012, 08:45 PM   #9
Correct....wouldn't.
Good catch.
Old 12-14-2012, 10:44 PM   #10
Good catch.
Better than my 0 tolerance comment above when I meant 0 clearance. Craving that beer after a long day I guess.
Trickle of Cold Water Pioneer Bathtub Faucet egawrons Plumbing 0 10-25-2012 12:24 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
Cold Air Coming In From Bottom/Underneath of Gas Fireplace Insert mark2741 HVAC 7 12-10-2010 10:05 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
COLD fireplace Ging HVAC 1 02-13-2008 07:12 PM
