Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 10-24-2011, 11:18 AM   #1
Fireplace Draught
Hello,
I have a Heat n Glo fireplace in my home. It is natural gas with an electric starter pilot. The vent is simply a metal housing that connects on the outside of the house through to the inner housing of the fireplace itself. There is a lower cavity below the fireplace, where the utilities (power and natural gas) feed into the unit.
When the weather gets cold (I live in Canada, so it gets very cold), I can feel a consistent draught from the hole in the lower cavity. I'm wondering what I can use to insulate and seal the hole? Any suggestions? I've attached pictures to illustrate what I'm talking about.
sjct is offline   Reply With Quote
Old 10-25-2011, 08:17 AM   #2
Exterior Construction
Windows on Wash's Avatar
Fireplace Draught
Closing off that hole will not eliminate the air that will coming from around that fireplace insert.
We typically remove the siding or exterior (if removable) and repair/seal it from that side.
Old 10-25-2011, 10:41 AM   #3
Fireplace Draught
Thanks Windows. I hadn't thought of that, but it makes sense. I guess the most likely source of the air coming through is the wall that the fireplace itself sits in.
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 12:37 PM
Fireplace construction question scottyv81 General Discussion 1 01-29-2011 10:26 AM
Fireplace Smell ...help wanted ! jasonb72 General Discussion 6 08-26-2010 07:02 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Possible to build direct-vent fireplace? DIYerself General Discussion 3 12-22-2007 11:07 PM
