Fireplace - Insulation - DIY Chatroom Home Improvement Forum
Old 12-03-2012, 10:09 AM   #1
Fireplace
Hello everyone. I have a fireplace in our family room that gets a bit drafty. The previous owners had a plexiglass cover to go over it when not in use. It has magnetic edges and the fire place opening has magnetic strips that are attached with double side foam adhesive. Has anyone seen these and or know where I can get replacement sections ?
blackws6ta is offline   Reply With Quote
Old 12-03-2012, 10:24 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
The are pretty easy to make.
If you aren't using the chimney, a chimney balloon work great too.
Old 12-03-2012, 11:12 AM   #3
Is a chimney balloon something that can be removed when needed and then replaced the next day when it cools down?
Old 12-03-2012, 01:06 PM   #4
Yes.
If you use the chimney on a regular basis, I would look into the spring loaded top mounted caps. They are also pretty airtight and a bit more easy on/off.
Old 12-03-2012, 01:17 PM   #5
Spring loaded tops ? Are those DIY installer friendly? Where could I find them? Thank you for the help.
Old 12-03-2012, 06:57 PM   #6
If you are comfortable on your roof, they can be DIY.
Don't get up there if you have no business being up there.
https://www.google.com/#q=spring+loaded+chimney+top+damper&hl=en&tbo=d&so urce=lnms&tbm=shop&sa=X&ei=Tjy9ULagN6aV0QGxkoDoAQ& sqi=2&ved=0CAYQ_AUoAA&bav=on.2,or.r_gc.r_pw.r_cp.r _qf.&fp=5ee40ca5d1959cd8&bpcl=39314241&biw=1440&bi h=697
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 10:56 PM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 10:26 AM
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 07:02 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
