#1 |
finishing walls of basement
If I am using wood against basement walls or floor ,does the wood have to be pressure treated?
#2 |
Exterior Construction
Anywhere wood meets concrete, it should have a capillary break or be PT lumber.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Thanks.Would that quote be according to building code in Nova Scotia?
#4 |
That rule applies to concrete that is in contact with the soil.
If there are breaks or joints to interrupt any transfer of moisture from the soil. Wood is often used in contact with concrete in above grade uses and often it is beneficial in drawing moisture out of the adjoining materials to stabilize the moisture content, such as a wall in a shool filled with hot, steamy kids for 8 hours per day. It can be a stabilizer just as it does to be thermal "heat sink" on a long term basis for minimizing mechanical equipment sizing (like a solar home). Dick |
| The Following User Says Thank You to concretemasonry For This Useful Post: | Windows on Wash (08-20-2012) |
#5 | |
finishing walls of basementQuote:
You 100% correct. I was assuming (we know what that means) earth to concrete contact given the basement designation.
| Display Modes | |
| Finishing Basement - Framing with 2x2's | mark2741 | Building & Construction | 13 | 12-25-2011 08:20 PM |
| Planning on finishing my basement gradually | fenders | Building & Construction | 7 | 12-24-2011 01:31 PM |
| Finishing Basement Wall - Stairs Along Concrete | Rob1976 | General Discussion | 5 | 02-02-2011 09:39 AM |
| How to solve problem of moist basement walls | moist | Building & Construction | 4 | 08-30-2010 06:18 PM |
| removing concrete parging from basement foundation walls. | newzev | Remodeling | 1 | 07-24-2009 09:17 AM |
