Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 09-14-2011, 07:37 PM   #1
Finishing my basement: wall insulation?
Hi all. First post. Been lurking for a while trying to find some answers to convince myself I can tackle my basement finishing project.
My home is in Freeland MI, zone 5 for insulation code purposes. My basement has poured walls, excellent drainage and radiant heat tubes in the floor and is unfinished. I'm going to stud frame and drywall the walls. Should I put a vapor barrier between the poured wall and the stud wall? Or, should I not install a vapor barrier so the wall cavity can breathe and just insulate the wall cavities? Any input would be appreciated. Thanks.
1jumper is offline   Reply With Quote
Old 09-14-2011, 08:10 PM   #2
Not a Noob or Boob
VB goes on the warm side. I prefer spray foam insulation which acts as insulator and VB.
Rob1975 is offline   Reply With Quote
Old 09-14-2011, 08:33 PM   #3
So, paper side of the insulation facing the inside, against the backside of the drywall? That makes sense now that I think about it. How else would I install it!? Duh! What about Visqueen plastic sheet against the wall?
Old 09-14-2011, 09:15 PM   #4
Not a Noob or Boob
VB goes on warm side. Drywall, plastic, studs, and insulation.
Old 09-14-2011, 10:04 PM   #5
Moderator
No vapor barrier or vapor retarder asphalt paper-faced on walls below grade: http://www.buildingscience.com/docum...lation-systems
Removed in 2009 IRC - no vb in basements.
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
AGWhitehouse (09-15-2011)
Old 09-15-2011, 10:01 AM   #6
Thanks for the replies. They answered my questions.
Old 09-15-2011, 11:29 AM   #7
Architectural Designer
AGWhitehouse's Avatar
DO NOT put in plastic!
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Townhouse basement insulation benb Building & Construction 0 02-15-2011 10:32 AM
Basement wall insulation Dman33 Building & Construction 1 02-14-2011 12:54 PM
basement wall insulation question Nox06 Building & Construction 0 02-14-2011 03:39 AM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 06:44 PM
