Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 10-23-2012, 07:57 PM   #1
Finishing the garage with insulation and drywall.
I want to finish my garage with insulation and drywall. It is a ranch style home with an attached garage. The attic above the house is open to the attic area above the garage. I do not plan on heating the garage. I just want it to be warmer than outside during the winter months. I am worried about the effects of moisture.
1. I plan on putting 9" insulation in the garage ceiling and 3/12" insulation in the walls.
2. Should I isolate the attic area above the house with a wall between the attic above the garage?
3. Should I use a moisture barrier in the garage walls (walls that face the outside) or ceiling?
4. Should a moisture barrier be used in the wall between the house and garage?
5. Should I install moisture resistant drywall (5/8" for ceiling and 1/2" for walls?
6. Should I install a ventilation fan?
7. Should a drain with a drywell be installed to cut down on water build up from melting snow?
Any help would be greatly appreciated.
Snapper12 is offline   Reply With Quote
Old 10-23-2012, 10:59 PM   #2
Before anyone can ansewer insulation or venting related questions you need to go back and edit you profile with your location.
Old 10-24-2012, 07:14 AM   #3
I live in Michigan so it can get below 0F quite often.
Finishing drywall in garage Chavez2049 Drywall & Plaster 8 10-17-2011 10:12 AM
Repair of drywall. Noticed bad insulation yardlady General Discussion 3 09-04-2011 08:50 AM
Garage Attic Insulation Questions H2O Engr Building & Construction 3 10-01-2010 10:00 AM
Garage insulation - to replace or not, and related questions DaveinGA Remodeling 6 12-20-2009 11:25 AM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 08:41 AM
