Finishing Basement In Townhouse, Insulate Side Common Walls? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 03:42 PM   #1
Rewards Points: 304
Finishing basement in townhouse, insulate side common walls?
Well, I'm redoing/finishing the basement, and the home is a townhouse. I have common walls on both sides, and the walls are poured concrete I'd say about 7 ft up, and then there's cinder block. The townhouse has a walk out basement, but the front of the townhouse you walk in on the 2nd level.
Is it worth insulating the side walls that are common with my neighbor? I was originally just planning on installing bat insulation, but would love other opinions. Would it provide much thermal and/or sound insulation? Fortunately the concrete wall seems to provide a good deal of sound insulation, but if I'm going through the hassle of framing up the walls I might as well do it right. TIA! I'm located in Virginia.
-Mike
NewHomeDIYGuy is offline   Reply With Quote
Old 02-14-2012, 04:30 PM   #2
Rewards Points: 12,790
Since there inside walls I see no need to do it.
Old 02-14-2012, 05:05 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 822
Only if you were worried about sound.
Old 02-14-2012, 10:22 PM   #4
Rewards Points: 304
Thanks for the input guys. So the question is would the bat fiberglass insulation provide much/any noticeable sound insulation? I'm installing insulation between the ceiling joists in the basement (to cut down on noise), but I'm starting to wonder if fiberglass insulation in the walls would even make a difference at all. Thanks!
-Mike
Old 02-14-2012, 11:27 PM   #5
Rewards Points: 822
Not much. The studs are the conduits for the noise at this point.
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
Insulate rim joist & basement walls- if exterior walls have no insulation? cbrc5eric Insulation 5 02-01-2012 08:47 AM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 09:39 AM
Insulate Side Walls of Row house acerunner Building & Construction 1 03-27-2010 12:11 PM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 01:21 PM
