Finishing attic insulation plan
1) I like your hat.
2) I'd prefer to seal and insulate the kneewalls rather than the roof deck in the attic areas, which turns that into conditioned space... That is unless you have a valid reason to not do so? I see that you are planning some sort of built-in unit, so perhaps that is your reasoning?
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
