Finished Attic Insulation And Ventilation Choices - Insulation - DIY Chatroom Home Improvement Forum
Old 10-28-2012, 11:30 PM   #1
Finished attic Insulation and ventilation choices
I have a 1.5 story ranch in PA with an attic that I am finishing. I am insulating first but have questions about whether or not I have adequate ventilation. I have a 70 ft attic with a continuous ridge vent at the peak the entire length. In the rear center of the attic is a 40 ft dormer with soffit vents below but only on the rear of the house. The front and the ends of the home are a cathedral ceiling with no soffitt vents. I am concerned about having enough ventilation throughout and am wondering if I need to add soffits on the front and ends, or maybe roof vents to increase airflow between the bottom and ridge vent . Or maybe somebody has other ideas I haven't thought of...any thoughts are appreciated.
PAFixerUpperGuy is offline   Reply With Quote
Old 11-02-2012, 11:02 PM   #2
Registered User
Rewards Points: 5,498
Welcome to the forums!
To get started, figure out what you need: http://www.airvent.com/homeowner/pro...it-specs.shtml
Some ideas on vented attics: http://www.buildingscience.com/docum...on?full_view=1
Gary
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Air sealing, ventilation, and attic insulation project-need advice Badfish740 General DIY Discussions 4 06-01-2011 06:48 AM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-02-2010 11:38 PM
Extending finished attic insulation stops? Mitch H HVAC 2 12-09-2009 11:00 AM
Finished attic insulation and ventilation issues diyfreak Roofing/Siding 1 10-07-2008 11:01 PM
