Is This Fiberglass Insulation Safe (touching Heating Duct)? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 03:04 PM   #1
Rewards Points: 12
Is this fiberglass insulation safe (touching heating duct)?
So the upper level of our house extends about 18 inches further than the lower level (there's a small "overhang" with soffits outside). As such, this heating air duct extends into that 18" soffit area where there's a 90 boot that goes directly into the upstairs floor vent.
With no insulation in that 18"x15" area between the joists, there's freezing cold air coming in -- so it clearly needs to be insulated. But I was a little concerned around this duct and wasn't sure if I should be. This is just R19 fiberglass insulation, cut in half to fit around the duct (18" deep to fill the cavity), with the kraft facing along the top (bottom of the floor) and facing the downstairs room.
Are there any issues with heat, with the insulation tucked right against the duct? Fire hazard with the kraft paper? Fiberglass particles/fibers getting into the duct and blowing upstairs? (The duct is well sealed with aluminum tape, but still...) Or is this all good for this setup? Any advice would be great. Thanks!
Is this fiberglass insulation safe (touching heating duct)?-1.jpg   Is this fiberglass insulation safe (touching heating duct)?-2.jpg   Is this fiberglass insulation safe (touching heating duct)?-3.jpg
nutlog is offline   Reply With Quote
Old 01-24-2012, 04:32 PM   #2
AGWhitehouse's Avatar
No fire hazard there. Looks well sealed, so no fiber blowing there.
Just make sure you insulated the back side of the elbow so you don't permit condensation within the duct. Since you've sealed off the warm air entering that void you now have an un-insulated duct traveling through a cold space. The warm, moist air within the duct will come in contact with the cold duct wall and potentially condense. Ensuring the entire bay is filled with insulation will help to avoid this condensation.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 01-25-2012, 02:53 PM   #3
Rewards Points: 12
Great, thanks.
It should be pretty well insulated all the way around the duct. I was a little worried about the heat and the kraft paper before I put the ceiling panels back up, but if we're all good here then it looks like I can finally finish up this room.
Old 01-26-2012, 03:27 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
You are not heating that duct to anywhere near the ignition temperature for paper.
Old 01-26-2012, 05:14 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 710
I agree with the others.. Insulate/seal that duct from the cold as best you can, then button it up.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-26-2012, 08:46 PM   #6
If the duct is getting that hot you have bigger problems.
http://www.tcforensic.com.au/docs/article10.html
The Following User Says Thank You to Yoyizit For This Useful Post:
AGWhitehouse (01-26-2012)
Old 01-27-2012, 08:18 PM   #7
Registered User
Rewards Points: 4,888
The cantilevered joists over the exterior wall are under-insulated if that one piece of fiberglass batt (in each cavity) is blocking air movement over the wall and there is no more insulation behind them. The outside joists should be insulated with cavity insulation, and foamboard (then plywood/siding) to stop the thermal radiation to the ground outside; http://www.buildingscience.com/docum...n-crawlspaces/
First add foamboard at the cantilever rim joist as solid wood is only R-1.25 per inch......
The room ceiling joists should have been covered with drywall, then your existing drop ceiling, due to the open "V"'s between the vertical ship-lap siding wall application (behind the ceiling grid end rail on the wall). These open raceways will spread a room fire to anywhere the joist travels above, very effectively. 1/4" wood paneling is fine, though because of the moisture coming through the cantilever area, the panels appear bowing; http://publicecodes.citation.com/ico...002_par017.htm
That wood burns very fast due to the poly finish on it.
Gary
Fiberglass insulation or fiberglass free decksrus Building & Construction 6 11-07-2010 09:48 PM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 03:50 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
Exposed fiberglass insulation in partially-finished basement skysurf Building & Construction 1 04-11-2009 10:40 AM
Is fiberglass insulation safe for us with dishwasher? jen78fl General DIY Discussions 10 01-31-2008 06:51 PM
