Fiberglass Insulation With Foil Backed Foam Sheathing - Insulation - DIY Chatroom Home Improvement Forum
Old 02-01-2012, 07:46 AM   #1
Fiberglass insulation with foil backed foam sheathing
I'm insulating my unfinished garage and the exterior walls have foil backed foam sheathing behind the siding. So from the inside of the garage I see the foil side of the sheathing. What kind of insualtion is recomended to fill in the wall cavity between the studs? Faced fiberglass insulation or unfaced? Does the foil from the sheathing provide the vapor barrior?
Thanks.
thedudeabides! is offline   Reply With Quote
Old 02-01-2012, 07:48 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,268
Foil = Class I vapor retarder in most cases so no facings on the insulation.
Make sure you drywall and wall details are air tight.
Old 02-01-2012, 10:48 PM   #3
Rewards Points: 1,092
What WoW is getting at is having a surface for any moisture to condense on once you seal up the wall, ie, the foil face, is not the greatest set up. IF you have a vapor barrier, and you probably should not, anywhere in the wall, it should be on the inside, or at least no more than 1/3 of the "R-value way" through the wall. I'd peel as much of the foil off as is practical, though unless the edges of the foam are sealed well it MAY NOT be a problem. Safer w/out it, IMO. Roxul between the studs, or dense packed cellulose, then air seal the interior sheathing and penetrations.
Vapor sealing with open cell foam insulation PerpetuallyRepairing Insulation 6 12-17-2011 09:16 PM
removal of exterior sheathing to apply spray-foam insulation from the outside raymaccallum Building & Construction 4 03-24-2011 05:52 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 04:42 PM
