Fiberglass Insulation In Basement? - Insulation - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 12:50 AM   #1
Rewards Points: 172
Fiberglass insulation in basement?
Just bought a brand new home in July. I'm finishing the basement. I already started framing with 2x4's 1 inch from wall. Will the rolls of fiberglass insulation with the paper facing be fine?
nateshirk is offline   Reply With Quote
Old 03-30-2011, 07:42 AM   #2
There are a lot of resources online regarding insulation in basements.
I wish there was some consistency between them!
You can definitely use fiberglass in a basement.
pyper is offline   Reply With Quote
Old 03-30-2011, 02:10 PM   #3
Rewards Points: 172
Yes. SOOOO many different opinions. That's why I thought I'd try to get a little more specific advise. Or maybe someone else could at least tell me they did it with no problem, even though time will only tell the whole truth.
Is the paper facing considered a vapor barrier? Thought I read that somewhere.
Old 03-30-2011, 05:42 PM   #4
Search for ROXUL on Google. Its much better for insulating basements as it doesn't absorb moisture.
Has a greater R value/in. than f/g also!
Old 03-30-2011, 07:41 PM   #5
Registered User
Rewards Points: 5,236
Where are you located?
Will you be using foam board first? http://www.buildingscience.com/docum...ent-insulation
Seal the rims first; http://www.buildingscience.com/docum...m-at-rim-joist
Gary
Old 03-30-2011, 11:07 PM   #6
Rewards Points: 172
Gary
I was trying to avoid foam board. I live in PA where we get all kinds of weather. I'll look into sealing the rim joist.
Old 03-31-2011, 12:48 AM   #7
Registered User
This will get you started; Basement Framing
Gary
Old 03-31-2011, 06:32 PM   #8
When I finished our basement I used john mansville insulation I got from menards. The batts were encapsulated in plastic. They were actually made for basement walls.
Jbyrd is offline   Reply With Quote
Old 04-02-2011, 10:02 PM   #9
Registered User
http://www.buildingscience.com/docum...ts?full_view=1
http://www.buildingscience.com/docum...gs?full_view=1
There is a lot of good info on basement insulation, try the white box above this page and hit "search" box...
No air gap, sill sealer under p.t. plate, ADA, fire-stop every 10' lineally, etc.....
Gary
Old 04-04-2011, 06:52 PM   #10
Rewards Points: 172
Wow.. thanks for all the tons of info in those links, but my brain is too tired to read all that right now.
Basically, just keep all basement air from reaching the cement wall? And seal the rim joist?
Old 04-04-2011, 08:26 PM   #11
Home Performance
HomeSealed's Avatar
Rewards Points: 712
GBR's comments and everything on buildingscience.com are right on. This info is consistent among those who know proper procedures.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-04-2011, 09:03 PM   #12
Experienced
Jackofall1's Avatar
Depending on where you live you may be posting back in a couple of years on how to do mold remediation.
You really should check out building science, they have the right stuff, developed by both solid engineering and lab testing.
Old 04-04-2011, 09:04 PM   #13
Experienced
Jackofall1's Avatar
Originally Posted by Powerup26 View Post
Fiberglass is fine, every builder ive worked for uses the fb insul on the basement walls and also for finished basement walls. If your house is properly sealed on the outside foundation then you shouldnt have a prob with moisture.
I every builder jumped off a bridge would you follow?, you really do need to do some solid research.
Mark
Old 04-04-2011, 10:52 PM   #14
Actually 6 years later and a 125 gallon saltwater tank later no problems here.
Old 04-05-2011, 10:04 AM   #15
Home Performance
HomeSealed's Avatar
Rewards Points: 712
There is a right and a wrong way to complete any project. Recommending a method just because you have personally not had any issues with it does not make it correct and is irresponsible. I've seen roofs with 5 layers of shingles that looked nice and didn't leak, shower tile installed on drywall that looked nice and didn't leak, and windows installed with no flashing or insulation that looked nice and didn't leak... That doesn't make any of those methods proper, and should be avoided at all costs, just as framing or fg insulation in direct contact with a foundation wall should be avoided at all costs (even if it is wrapped in plastic).
www.HomeSealed.com
The Following User Says Thank You to HomeSealed For This Useful Post:
Jackofall1 (04-05-2011)
Basement wall insulation dandw12786 Building & Construction 4 07-15-2010 02:11 PM
Finished Basement Insulation cdhen14 Building & Construction 0 06-03-2010 06:43 AM
Same old Question basement Insulation advice rp92285 Building & Construction 2 02-05-2010 12:01 PM
Basement Insulation question tophercole Building & Construction 0 11-19-2009 10:01 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
