Fiberglass Atic Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 12-09-2013, 09:12 AM   #1
bryanp22's Avatar
Rewards Points: 290
Fiberglass atic insulation
I have an older home with fiberglass attic insulation. It's unfaced and I currently have two layers. How can I tell what R value these two layers provide? I am in milwaukee wi so I need R49. I am trying to decide if a third layer would be required.
bryanp22 is online now   Reply With Quote
Old 12-09-2013, 11:13 AM   #2
Rewards Points: 1,008
Try this insulating schedule of many available.
http://www.homeadditionplus.com/insu...Comparison.htm
Old 03-23-2014, 10:17 AM   #3
bryanp22's Avatar
Rewards Points: 290
Okay so now that is a little warmer I probably have around R30 in my attic currently. Is it okay to add a third layer of R30 fiberglass or does the weight of the R30 start to be a concern for the two exiting layers that I have?
Old 03-23-2014, 01:31 PM   #4
Rewards Points: 13,468
Not going to be an issue.
Old 03-23-2014, 01:33 PM   #5
Really should be adding baffles to keep from blocking the air flow from the soffits to the roof vents.
Old 03-23-2014, 03:10 PM   #6
bryanp22's Avatar
Rewards Points: 290
I have no soffits. Old house from 46 that architecture review commission for village won't let people modify the roof line to add a soffit
Improving attic insulation: remove old fiberglass or just add cellulose/fiberglass? DrSteveBrule Insulation 12 10-21-2013 11:42 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Sound Insulation: Fiberglass or Denser "Safe n Sound" psubaron Insulation 1 09-07-2011 10:32 AM
Blown-in Fiberglass Attic Insulation jdieter Building & Construction 14 11-21-2010 12:39 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
