Fiber Faced Poly Iso Board Vapor Barrier - Insulation - DIY Chatroom Home Improvement Forum
Old 10-29-2013, 10:46 AM   #1
Fiber faced Poly Iso board vapor barrier
Hi I just got a lead on some cheap "reclaimed" Poly Iso boards and I am considering insulating my attic with them(currently uninsulated). The board has the black backing, not foil, which seems to be known as fiber faced. There are 1000x posts on foil backed but cannot find much info on fiber backed. I live in upstate NY and would like to buy and install this the right way asap. Thanks for the help all!
CDiablo is offline   Reply With Quote
Old 10-29-2013, 10:52 AM   #2
Excuse me, I mean felt faced not fiber.
Old 10-30-2013, 01:00 PM   #3
Registered User
Rewards Points: 526
Welcome to the forums!
The fiberglass faced would stop any moisture trying to exit the rooms below to the attic space where it would be removed by ventilation. I would use something more permeable, (over the <1 perm) especially if you already have a vapor barrier/retarder poly/craft-faced next to the ceiling drywall/plaster. http://www.menards.com/main/building...632-c-5779.htm
http://www.google.com/url?sa=t&rct=j...,d.cGE&cad=rja
Air seal the attic first, before all else; http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
Gary
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 12:21 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Fiber board duct & humidifier BigD HVAC 1 12-26-2007 06:04 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
