Faced Or Unfaced - Insulation - DIY Chatroom Home Improvement Forum
Old 06-18-2013, 11:00 PM   #1
Rewards Points: 117
faced or unfaced
Howdy all,
I am getting ready to purchase the fiberglass insulation for my basement remodel.
Some info...It is a condition area. I live in Newark Delaware. I already put 2" XPS rigid foam directly on the concrete walls and also in the rim joists. I have two questions...
1) should I put faced or unfaced fiberglass in the rim and band joist on top of the XPS?
2) should I use faced for unfaced fiberglass in the 2x4 wall cavities?
tommyxv is offline   Reply With Quote
Old 06-19-2013, 07:17 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,608
Unfaced on both if it were my home. The painted drywall should serve as your vapor control layer and class III vapor retarder.
I don't have the codes handy on my phone but I think, will have to check, you don't need one.
Use the air tight drywall approach.
Here you go: http://www.buildingscience.com/docum...commendations/
Don't need one.
Old 06-19-2013, 07:25 AM   #3
Rewards Points: 117
Thanks for the reply. I see you are not too far from me, all the HD and Lowes don't seem to carry unfaced r-13 for the wall cavities, maybe r-19 for the rim/band joists. I guess just removing the kraft paper is the easier way to go?
Old 06-19-2013, 07:27 AM   #4
Order it or use Roxul.
That or call an insulation supply house.
Old 06-19-2013, 07:32 AM   #5
Rewards Points: 117
I will probably order it then. I'm having HD deliver 80 sheets of rock soon so I will just add it to the order.
Thx
Old 06-19-2013, 03:57 PM   #6
Registered User
Rewards Points: 5,514
Unfaced in the wall, faced in the rims. You are in Zone 4, XPS over 1" thick with dew-point at 45%RH, Fig. 2- center; http://www.buildingscience.com/docum...nd-wall-design
Gary
Old 06-19-2013, 04:03 PM   #7
Rewards Points: 117
Gary
Is it bad that I used 2" XPS?
Old 06-19-2013, 05:02 PM   #8
Registered User
No, that's fine. Figuring your location, three coldest months average temps http://www.usclimatedata.com/climate...ation=USDE0043 of 35*F minus the 68*F basement temp = 33*F inside foamboard temp with R-19 floor insulation = 46*F/45%RH foamboard temp/relative humidity. Very close to the 45*F of the link, asphalt paper-faced would be best. Especially as the rim will be closed off from the direct heat transfer as a wall, it will run cooler equals; higher dew-point there to wet the framing. Use a low-expanding canned foam (window/door) rather than "Big gap filler" closed-cell= with less "give" for movement if an older house without new "engineered" framing; http://www.buildingscience.com/docum...d-but-strange/
Gary
PS. you could also use less fibrous insulation to keep the f.b. warmer if already ordered...
Old 06-19-2013, 05:18 PM   #9
Rewards Points: 117
Gary you got me very confused now. LOL
I have not ordered any fiberglass yet. As of right now, I put 2" XPS in all the rim and band joists with spray foam to seal around the edges. I attached 2" XPS to all the concrete walls, seams caulked and taped with Dow Weather-mate.
2x4 walls are already framed tight to the XPS.
What is my next step then?
Old 06-20-2013, 07:37 PM   #10
Rewards Points: 117
Sorry for the bump... I am ordering the insulation tomorrow along with 70 sheets of mold resistant rock and want to make sure I am clear on what I should be ordering.
1) Faced fiberglass (preferrably asphalt paper-faced) on top of the 2" XPS foam board in the rim and band joist.
AND
2) Unfaced fiberglass inside 2x4 wall cavities.
Note: All walls and ceilings will be dry-walled
Thanks!
Old 06-20-2013, 09:09 PM   #11
Registered User
Faced in the rims is correct, IF there is no more additional foamboard on the exterior there (it all has to do with the permeability of the siding/sheathing, including f.b.). Unfaced on the walls. With the Code required R-19 and your R-10 XPS, a cavity insulation of R-13 or R-15 (Roxul) is all you need. This (less mass cavity fiber) will raise the dew-point to a safer 51%RH in the rooms before condensation.
Gary
Old 06-20-2013, 09:46 PM   #12
Rewards Points: 117
Thanks for the reply. I really like the Roxul product. I will have to see the total cost difference btw fiberglass and it.
I plan on running a dehumidifier as extra protection. My basement is dry with no leaks. I did the plastic on the slab test I only get a small damp/darker spot on the concrete after a few days, no water on the plastic.
Thanks again for you input and help.
Old 06-21-2013, 07:08 AM   #13
You won't need to run a dehumidifier if you insulate the basement as you are proposing. That space will be tight as a drum and you won't have any humidity issues.
Old 06-21-2013, 08:25 AM   #14
Rewards Points: 117
very good then.
Old 06-21-2013, 04:05 PM   #15
Rewards Points: 626
Unfaced! Easier to deal with
Nailbags is offline   Reply With Quote
Insulation : Faced and unfaced Alan Insulation 10 02-25-2012 09:01 AM
Faced or unfaced? msaeger Insulation 20 09-09-2011 10:04 AM
Insulation - Faced vs. Unfaced + Plastic Sheet WaldenL Building & Construction 4 07-06-2011 11:41 AM
Faced vs unfaced insulation in basement? mathias400 General DIY Discussions 0 05-19-2010 10:01 PM
Faced or Unfaced Insulation in Attic??? capenpeck Building & Construction 13 11-06-2009 07:23 AM
