Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-26-2012, 10:54 AM   #1
Faced Inuslation
We have faced insulation should we put plastic over that before we sheetrock our walls?
georgezietz is offline   Reply With Quote
Old 01-26-2012, 11:27 AM   #2
Exterior Construction
Windows on Wash's Avatar
Faced Inuslation
Depends? What is the facing on the insulation?
Questions:
  • Where is the home located
  • What room are you insulating
  • What is the exterior of the home in those areas
  • any other details...
Old 01-27-2012, 01:21 PM   #3
Faced Inuslation
Before you put up any poly, it may be advisable to read more about their "need" or potential problems therefrom. Most areas of the country do not need them, air sealing and vapor retarding instead. If you are going to ever run air conditioning, poly can be very problematic (as is wet, rotting walls). Buildingscience.com is a great place to start.
The Following User Says Thank You to jklingel For This Useful Post:
Windows on Wash (01-27-2012)
Insulation - Faced vs. Unfaced + Plastic Sheet WaldenL Building & Construction 4 07-06-2011 12:41 PM
insulation - faced or unfaced and which direction neil buckner Insulation 0 05-23-2011 11:22 AM
Faced vs unfaced insulation in basement? mathias400 General Discussion 0 05-19-2010 11:01 PM
19" spaced joists - foil faced insulation? CWorth Remodeling 3 03-21-2009 01:26 PM
Kraft Faced Batts in Interior Wall Earnie Building & Construction 2 01-24-2008 09:52 AM
