faced insulation in wall where to staple
This is a very small bathroom, no bigger than 7 x 8. There are only 2 exterior walls that need insulation. No insulation in walls prior to demo. This is an older 60's home: 1 wall has the older fiber blackboard with brick exterior over it and the other has black roof paper and cedar boards.
The second exterior wall with roof paper and cedar, will be replaced soon with: hardie/Tyvek/OSB. The room side of this wall composes: one side of this wall is one side of the standup only shower which will be done in Tile/schuster shower system/hardibacker 1/2 inch nailed directly to the studs. The rest of this same wall will be the sink/cabinet and mirror.
Yes I will be caulking around the floor studs wall frame.
So am I understanding you guys that I dont need the krafed insulation?
