Faced Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 08-04-2013, 08:06 PM   #1
faced insulation
hello
does the paper with flaps go inside or outside when installing
fcr0wley is offline   Reply With Quote
Old 08-04-2013, 08:41 PM   #2
Rewards Points: 6,652
They go over the face of the studs, so that you get a continuous vapor barrier. First off, where do you live? Also how old is the structure, and is there something like Tyvek on the outside of the structure already?
Old 08-04-2013, 08:47 PM   #3
thanks Gregzoll
im in new york upstate, we doing a basement ceiling no prior installation
we have rolls of r19 faced installation, neighbor mention the paper side goes in first not the pink
just curious
Old 08-04-2013, 08:50 PM   #4
Then you do not want to use faced insulation. Basements you need to use XPS Foam board, not the faced insulation. Look at the previous threads on basement insulating, and also http://www.buildingscience.com.
Old 08-05-2013, 01:37 PM   #5
Registered User
Rewards Points: 5,216
Don't need insulation in basement ceiling for R-value, is this for sound proofing?
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
concretemasonry (08-05-2013)
Old 08-05-2013, 03:36 PM   #6
All
basement high in moisture, there was no prior installation on walls. floor ceiling
purpose eliminating the cold for the winter
Room Floors usually cold during those months
Im trying to keep the cold out at least to a minimum
usually a wood stove to heat house currently
Thanks for the inputs
1950 house
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
R-30 Faced/ unfaced insulation bhanse Insulation 6 01-08-2012 08:29 PM
Foil faced rigid insulation question 123ozzie Insulation 3 12-11-2011 02:18 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
Faced or Unfaced Insulation ? - Room below porch buchmana Building & Construction 2 02-01-2010 10:29 PM
