Faced Fiberglass Batt Installed Backwards - Insulation - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 01:10 AM   #1
faced fiberglass batt installed backwards
In an unfinished basement (walkout basement), is it common (or okay) to install faced fiberglass insulation in the wood framed wall with the paper toward the outside?
I figure this was done to pass fire code, but will it create vapor issues?
88bomber is offline   Reply With Quote
Old 02-04-2013, 01:25 AM   #2
Rewards Points: 13,250
Please go back and add your location to your profile, yes it makes a differance.
Old 02-04-2013, 09:05 AM   #3
Rewards Points: 626
The only place I know of were one can put the kraft face batt to the out side is Florida.
Nailbags is offline   Reply With Quote
Old 02-04-2013, 09:12 AM   #4
I'm in east Tn.
~1200ft
My assumption is that the installer didn't have any unfaced in the truck, so he turned it backwards so he wouldn't have to cover it (with drywall) to meet code.
I do plan to finish the basement, but probably not for 1-3 years...will I be okay until then?
Old 02-04-2013, 12:17 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
The problem you have is twofold. The paper facer acts as a vapor retarder and should be placed toward the "warm in Winter" side of the floor or wall assembly. The second problem is that the facer, being exposed, presents a combustion hazard and needs to be covered.
Old 02-04-2013, 02:45 PM   #6
Rewards Points: 626
I'm in east Tn.
~1200ft
a simple solution to your problem is just gently pull the kraft face off.
Old 02-05-2013, 09:48 PM   #7
The problem is, that's what's holding the insulation in place.
Old 02-05-2013, 10:23 PM   #8
Rewards Points: 626
batts are held by friction and if the kraft is facing the cold side what are they stapled to? Nothing easy enough to just pull them out and turn them around or remove the kraft paper.
Old 02-05-2013, 11:28 PM   #9
Registered User
Rewards Points: 5,204
http://www.buildingscience.com/docum...endations/#Map
Gary
Old 02-06-2013, 12:57 PM   #10
I'm in zone 4a...so does that mean I NEVER have to use interior vapor barrier...regardless of class 1, 2 or 3?
Old 02-06-2013, 02:25 PM   #11
Rewards Points: 626
No I live in zone 4 what is required to have a vapor retarder.
Old 02-06-2013, 02:29 PM   #12
nailbags, I'm guessing you are in zone 4c, which is required to have a class 1 or 2 vapor barrier. (according to the link provided by Gary above)
Also from that link...
"No interior vapor control required on the interior side of framed walls in climate zones 1, 2, 3, 4a, or 4b. In hot, humid climates, a Class I or II vapor control layer on the interior of the framing can, and often does, cause premature building enclosure failure due to inward moisture drive condensation (see RR-9302: Humidity Control in the Humid South). BSC recommends avoiding Class I or II vapor control layer on the interior in these zones, or any material that acts inadvertently like a Class I or II vapor control layer such as reflective foil insulations, vinyl wall coverings, glass mirrors and epoxy paints."
If that is indeed true, then why the heck do people tout the use of 2" XPS in rim joists (see other thread) which I believe is a class 2 vapor barrier?
Old 02-09-2013, 08:32 PM   #13
Registered User
The foam is on the outside of the warm cavity, next to the exterior- not at the drywall, but after the insulation.
Gary
The "biggest loser" in fiberglass insulation.... Gary in WA How To Guides 2 01-20-2015 07:19 PM
Insulation Installed Backwards/Advice cbaur88 Building & Construction 5 01-26-2011 11:40 PM
Wonderboard installed backwards Jim W Plumbing 4 07-12-2009 05:44 PM
Corrugated Fiberglass Roof theriver Roofing/Siding 1 09-16-2008 10:37 PM
Is fiberglass insulation safe for us with dishwasher? jen78fl General DIY Discussions 10 01-31-2008 06:51 PM
