-   Insulation (http://www.diychatroom.com/f103/)
-   -   faced fiberglass batt installed backwards (http://www.diychatroom.com/f103/faced-fiberglass-batt-installed-backwards-170960/)
88bomber 02-04-2013 12:10 AM
In an unfinished basement (walkout basement), is it common (or okay) to install faced fiberglass insulation in the wood framed wall with the paper toward the outside?
I figure this was done to pass fire code, but will it create vapor issues?
joecaption 02-04-2013 12:25 AM
Please go back and add your location to your profile, yes it makes a differance.
Nailbags 02-04-2013 08:05 AM
The only place I know of were one can put the kraft face batt to the out side is Florida.
88bomber 02-04-2013 08:12 AM
I'm in east Tn.
~1200ft
My assumption is that the installer didn't have any unfaced in the truck, so he turned it backwards so he wouldn't have to cover it (with drywall) to meet code.
I do plan to finish the basement, but probably not for 1-3 years...will I be okay until then?
Maintenance 6 02-04-2013 11:17 AM
The problem you have is twofold. The paper facer acts as a vapor retarder and should be placed toward the "warm in Winter" side of the floor or wall assembly. The second problem is that the facer, being exposed, presents a combustion hazard and needs to be covered.
Nailbags 02-04-2013 01:45 PM
Originally Posted by 88bomber (Post 1109181)
I'm in east Tn.
~1200ft
a simple solution to your problem is just gently pull the kraft face off.
Maintenance 6 02-05-2013 08:48 PM
The problem is, that's what's holding the insulation in place.
Nailbags 02-05-2013 09:23 PM
batts are held by friction and if the kraft is facing the cold side what are they stapled to? Nothing easy enough to just pull them out and turn them around or remove the kraft paper.
Gary in WA 02-05-2013 10:28 PM
http://www.buildingscience.com/docum...endations/#Map
Gary
88bomber 02-06-2013 11:57 AM
I'm in zone 4a...so does that mean I NEVER have to use interior vapor barrier...regardless of class 1, 2 or 3?
Nailbags 02-06-2013 01:25 PM
No I live in zone 4 what is required to have a vapor retarder.
88bomber 02-06-2013 01:29 PM
nailbags, I'm guessing you are in zone 4c, which is required to have a class 1 or 2 vapor barrier. (according to the link provided by Gary above)
Also from that link...
"No interior vapor control required on the interior side of framed walls in climate zones 1, 2, 3, 4a, or 4b. In hot, humid climates, a Class I or II vapor control layer on the interior of the framing can, and often does, cause premature building enclosure failure due to inward moisture drive condensation (see RR-9302: Humidity Control in the Humid South). BSC recommends avoiding Class I or II vapor control layer on the interior in these zones, or any material that acts inadvertently like a Class I or II vapor control layer such as reflective foil insulations, vinyl wall coverings, glass mirrors and epoxy paints."
If that is indeed true, then why the heck do people tout the use of 2" XPS in rim joists (see other thread) which I believe is a class 2 vapor barrier?
Gary in WA 02-09-2013 07:32 PM
The foam is on the outside of the warm cavity, next to the exterior- not at the drywall, but after the insulation.
Gary
