Face Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 09:23 PM   #1
face insulation
I'm about to drywall the living room this weekend, I insulated the exterior facing wall with R19 faced fiberglass Insulation & stapled the flanges of the insulation to the studs. should I lay a quick roll of vapor barrier across the wall before I drywall?
Thanks for your info \Level
Level is offline   Reply With Quote
Old 01-19-2012, 09:26 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
The paper on the insulation is the barrier.
titanoman is offline   Reply With Quote
Old 01-19-2012, 09:33 PM   #3
Rewards Points: 13,300
You do have 2 X 6 wall studs right?
R-19 will only fit in 6" deep wall bays.
2 X 4 would need R-13.
Old 01-19-2012, 09:40 PM   #4
Sorry I have 2x4 it is R13 my bad. I know the paper is a vapor barrier but for a few extra dollars, I can throw up a roll of plastic. would it hurt to install the plastic also?
Old 01-19-2012, 09:43 PM   #5
Yes that would be a double vaper barrier a big no no.
Old 01-19-2012, 11:16 PM   #6
Registered User
Rewards Points: 5,266
1. Depends on your location.
2. Depends on the exterior material make-up, eg.-- vinyl siding, foamboard, black paper, OSb, ---- could you describe it?
Gary
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 11:04 AM
Reusing Deteriorated Insulation a_lost_shadow Insulation 2 12-18-2011 05:27 PM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Yes, Another Basement Insulation Question Beepster Insulation 7 11-30-2011 07:30 PM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 10:57 AM
