-   Insulation (http://www.diychatroom.com/f103/)
-   -   face insulation (http://www.diychatroom.com/f103/face-insulation-130670/)
Level 01-19-2012 08:23 PM
face insulation
I'm about to drywall the living room this weekend, I insulated the exterior facing wall with R19 faced fiberglass Insulation & stapled the flanges of the insulation to the studs. should I lay a quick roll of vapor barrier across the wall before I drywall?
Thanks for your info \Level
titanoman 01-19-2012 08:26 PM
The paper on the insulation is the barrier.
joecaption 01-19-2012 08:33 PM
You do have 2 X 6 wall studs right?
R-19 will only fit in 6" deep wall bays.
2 X 4 would need R-13.
Level 01-19-2012 08:40 PM
Sorry I have 2x4 it is R13 my bad. I know the paper is a vapor barrier but for a few extra dollars, I can throw up a roll of plastic. would it hurt to install the plastic also?
joecaption 01-19-2012 08:43 PM
Yes that would be a double vaper barrier a big no no.
Gary in WA 01-19-2012 10:16 PM
1. Depends on your location.
2. Depends on the exterior material make-up, eg.-- vinyl siding, foamboard, black paper, OSb, ---- could you describe it?
Gary
