Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 09-22-2011, 07:32 PM   #1
JJboy's Avatar
Fabric tape for duct insulation
Do you know the name of this hvac insulation fabric tape?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-22-2011, 08:24 PM   #2
fabrk8r
fabrk8r's Avatar
jjboy, that looks like Hardcast brand 2 part sealing system.
It uses a fabric tape and mastic. You pull the tape through a trough with rollers which applies the thin mastic. The applicator looks kind of like a drywall finisher's tape trough and the mastic comes in 1 gallon jugs or 5 gallon pails.
I provided a link to Hardcast's website in your other thread on this matter.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-22-2011, 09:34 PM   #3
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
I have known stuff similar to this as "aero-ball" if I spelled that correctly when I was dong commercial A/C and sheet metal.
It is a water based glue with a canvas mesh.
It was a mesh alright.
Andy.
AndyGump is offline   Reply With Quote
Old 09-22-2011, 10:31 PM   #4
JJboy's Avatar
I checked the link but I couldn't find anything similar. I'll check again. Thanks
Old 09-22-2011, 10:33 PM   #5
JJboy's Avatar
Andy.
I don't think is a mesh tape... doesn't look like.....also the final job looks clean for any mastic applied on top of the tape
Old 09-23-2011, 12:44 AM   #6
JJboy's Avatar
Hey Andy, Do you think this is the right canvas?
http://www.grainger.com/Grainger/OWE...5&cm_vc=HPPVZ3
Old 09-23-2011, 01:41 AM   #7
AndyGump's Avatar
No that is not it. The stuff I used was a cloth mesh not fiberglass now that I remember.
Andy.
Old 09-24-2011, 11:00 AM   #8
fabrk8r
fabrk8r's Avatar
Here are some pics of what we used to use for sealing the joints and seams of underground duct systems.
The tape...
Closeup of the tape...
The dispensing system...
Now, having said all this I'm going to ask why you think you need this type of tape and mastic for duct that isn't exposed to the moisture intrusion and external pressure problems that underground duct is exposed to.
We don't even use this stuff anymore for underground systems because there are better and less expensive sealants that are easier to apply and less messy, such as Pro-Seal.
I would also like to add that the only time we ever even used the 2-part Hardcast system was on PVS coated metal, which is designed for underground duct.
The Following 2 Users Say Thank You to fabrk8r For This Useful Post:
JJboy (10-02-2011), Windows on Wash (09-25-2011)
Old 09-25-2011, 01:57 AM   #9
Exterior Construction
Windows on Wash's Avatar
+1
Why not just caulk or mastic the seams for re-sealing.
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Adding insulation and storage to Cape Cod Side Attic turin39789 General Discussion 5 11-08-2010 11:50 AM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 06:19 PM
What is Best for Joining Polyethylene Pipe Insulation? fritzycat1 HVAC 1 09-18-2009 03:52 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
