Exterior XPS - Insulation - DIY Chatroom Home Improvement Forum
Old 06-01-2014, 10:50 PM   #1
Rewards Points: 216
exterior XPS
i am going to be siding the back of my house kinda soon. just vinyl (cost).
i was told, in a thread i cannot find now, that i can just go over my current siding. which is asphalt and in servicable condition. i was told to just use fanfoil. but i want some insulation factor. so, can i just go over it. and, is 1" xps good for this ? or what ? what else do you need to knoww ?
Fix'n it is offline   Reply With Quote
Old 06-01-2014, 11:21 PM   #2
Rewards Points: 940
If I'm re-siding something, say something sided with the old clapboards or the lousy press-board, I like to remove this siding, deal with any doors and windows, then wrap the house properly and re-side. If you would like to add some xps, then I would suggest 1" tongue & groove.
cleveman is offline   Reply With Quote
Old 06-02-2014, 07:42 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
I would pull everything off, seal all the gaps and cracks, re-tape the nailiing flanges, install some T&G XPS (depth depends on your wall depth and climate), Tyvek/Housewrap, and new siding.
Be sure to include drip caps and rigid flashing details.
Old 06-02-2014, 01:51 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Good advice above... The best way is to tear it all off and then add the insulation board to the thickness of your choice. If you are set on not tearing it off, stick to the fanfold.
What do you have in your wall cavities for insulation?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Windows on Wash (06-02-2014)
Old 06-02-2014, 09:40 PM   #5
Rewards Points: 243
Isn't housewrap overkill if you already have XPS on the exterior?
chemman is offline   Reply With Quote
Old 06-02-2014, 09:42 PM   #6
Rewards Points: 216
ok, i figured you guys would say that. i am guessing it would come off somewhat easily. though a mess.
inside my walls. 2x4's with 1" furring added = 4 1/2 depth. . 1" xps caulked to seal it in cavity. then roxul.
i was planning 1" xps outside.
Old 06-02-2014, 09:43 PM   #7
Rewards Points: 216
i was thinking the same thing.
Old 06-02-2014, 10:45 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Not if you want a proper drainage plane/ lapping of flashing etc. Yes, taping of the seams can be effective, but I prefer a proper wrb for long term performance around the window and door openings.
www.HomeSealed.com
Old 06-02-2014, 11:10 PM   #9
Big +1 there.
Old 06-03-2014, 01:57 PM   #10
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Here is an example of why the wrb is still important. This home had an active water into the wall cavity.
www.HomeSealed.com
Old 06-03-2014, 03:11 PM   #11
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Since when can you not edit posts after 30 min? Weird...
Anyway, just wanted to add that in this particular situation, the seal of the head flashing to the xps failed introducing water into the wall cavity, and then someone installed replacement windows and capped over the original head flashing, introducing a second source of moisture. This one needed some sheetrock repair due to water damage.
www.HomeSealed.com
Old 06-03-2014, 09:02 PM   #12
Where is your finger?
The Following User Says Thank You to Windows on Wash For This Useful Post:
HomeSealed (06-04-2014)
Old 06-04-2014, 04:34 PM   #13
Rewards Points: 12
This is Cathy from DuPont. It’s a good idea to use a weather barrier with XPS or other exterior foam insulation. We recommend DuPont™ Tyvek® HomeWrap® on top of the foam or Tyvek® DrainWrap™ for enhanced drainage when installed under the foam. Also, DuPont does not recommend taping the foam seams regardless of whether the Tyvek® is installed under or over the foam. Not taping the seams will have very little effect on the foam’s R-value, and because of the low permeability of the foam, the open seams will help the wall breathe.
DuPontTyvek is offline   Reply With Quote
The Following User Says Thank You to DuPontTyvek For This Useful Post:
