Exterior Wall Insulation Iowa Climate - Insulation - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 12:12 AM   #1
Rewards Points: 156
Exterior wall insulation iowa climate
Hey everyone,
I think I have a void in my wall cavity in my master bedroom. When it's cold outside I feel a draft in a certain area. That same area gets colder to the touch than other places on that same wall.
I have some plugs in the siding which tells me that previous owners blew in wall insulation. I'm not sure if it's cellulose or fiberglass, but I think it's yellow (saw some insulation in the walls when putting dishwasher in).
So what should I do in this situation? Can I just rent a machine and blow in more insulation? Is it likely to fill that void on the wall cavity? Or is spray foam a better choice in this situation?
strategery is offline   Reply With Quote
Old 02-16-2012, 02:34 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,622
You cannot properly dense pack with the DIY machines.
Have an insulation company take a look at it and see what is missing.
Yellow would be fiberglass in this case.
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
Loose fill asbestos insulation, Vermiculite GeauxCajuns82 Building & Construction 2 03-07-2011 05:59 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
super insulation retrofit with rigid insulation hostaking Building & Construction 5 01-07-2009 10:23 AM
