Exterior Wall Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 09:32 AM   #1
I have a walkout basement wall that is needs insulation. I need to insulate this wall properly. Te insulation I purchased is Owen Corning (R-15) insulation with paper backing. What is the proper position of the insulation, paper out or paper in?
Goodball is offline   Reply With Quote
Old 09-02-2012, 09:41 AM   #2
Rewards Points: 13,712
Paper always goes toward the conditioned side of the wall.
(The side that heated and cooled)
Old 09-03-2012, 07:49 PM   #3
Registered User
Rewards Points: 5,514
Yep, toward the heated side, inside in a heating climate, outside in a cooling climate; map; http://www.energysavers.gov/your_hom.../mytopic=11810
Gary
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 06:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
