Exterior Curved Roof Insulation. - Insulation - DIY Chatroom Home Improvement Forum
Old 01-21-2013, 09:17 AM   #1
exterior curved roof insulation.
I will build a Japanese style garden outbuilding with a curved roof. The plans come from S. California but the build is in the Northeast. The ceiling will be exposed knpotty pine or spruce
To extend its use into the cooler seasons I will use an electric heater. But would like to put something with insulating value on the exterior of the roof below shingles. It needs to be flexible to follow the roof curve.
All suggests appreciated.
plschwartz is offline   Reply With Quote
Old 01-21-2013, 09:38 AM   #2
Rewards Points: 13,712
It would help is you added your location to your profile.
It would be great if somehow you could post the web site or something so we could get an idea on what this is going to look like.
One way I've seen it done was with 1-1/2 X 6" T&G then they used SIP roofing panels for added insulation and a nailing surface for the roofing.
http://www.raycore.com/roof-panels.php
The panels I saw used were only 1-1/2 thick. And were held down with special scews with large washers.
Wood only has an R value of only 1.25 per inch I believe.
Old 01-21-2013, 01:00 PM   #3
1. I live in long island NY
2.picture is http://woodsshop.com/Teahouse4.htm
The roof is actually curved. From woodsshop .com
So what I need is relatively thin and flexible as I want to keep the roof curve.
Over the planks should I put down tyvek, radiant barrier and or what?
thanks
Shed roof addition & insulation qustion radgumbo Roofing/Siding 2 12-06-2010 05:33 AM
Adding insulation to a low-slope roof cbeingessner Roofing/Siding 25 09-21-2010 11:01 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Add insulation to solid timber roof justinNC Building & Construction 2 11-01-2009 12:16 PM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 08:24 AM
