Extending 2x4 To 2x6 - Insulation - DIY Chatroom Home Improvement Forum
Old 09-20-2013, 06:32 PM   #1
Rewards Points: 41
Extending 2x4 to 2x6
So i want to add some 2x2 strips to my 2x4 studs to make them 2x6 which would give me space to fit in Roxul R23 which fits into a 5 1/2 inch stud (2x6). The issue im having is that my 2x4 are actually only 3 1/2 inch wide and the only 2x2 i can find are only 1 1/2 inch wide which gives me 5 inch studs. Am i able to compress the insulation 1/2 inch. Or should I do something else all together?
biddlecom is offline   Reply With Quote
Old 09-20-2013, 06:37 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,124
News alert....
A 2x4 is actually 1.5 x 3.5....been that way for a long time....2x6 is 1.5 x 5.5....
Maybe a bit more information...like where you live....what the existing wall is like....we are assuming that you have already pulled all of the drywall off...
Lacking any more info....if it was me....I would rip some 2x6's down the middle...or just sister 2x4's to the existing studs so that they stick out the depth you want.
Old 09-20-2013, 08:21 PM   #3
Registered User
Rewards Points: 5,216
Compressing it 1/2" will reduce the total R-value by around R-2, similar to R-15 (high density) fiberglass in 3-1/2 to 2-1/2" wall; http://www.greenbuildingadvisor.com/...fiberglass.JPG
Gary
PS. you will gain in density though; http://books.google.com/books?id=e5h...inches&f=false
Old 09-20-2013, 08:33 PM   #4
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 740
Rip some strips of 1/2'' plywood to put behind the 2x2's.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 09-21-2013, 06:32 AM   #5
Rewards Points: 222
i did that to square up a wall, and fur it out 1". it was a PITA to get the roxul to fit properly = every piece of roxul had to be custom trimmed/fitted = no fun at all.
biddle
decide what you want in the wall. find the thickness of it all. rip strips to the right size. caulk and nail them to the 2x4's.
been there, done both.
Fix'n it is offline   Reply With Quote
Extending deck & Pressure treated joist life OR DIY guy Building & Construction 2 05-23-2012 09:59 PM
Extending Patio Slab and adding a cover Jeoroc24 Building & Construction 5 04-12-2011 12:16 PM
Advice extending ridgeline of ranch house pfau Building & Construction 7 02-05-2011 11:08 AM
Extending cable for garden solar lights calibra Electrical 3 09-02-2009 11:47 AM
Extending an existing concrete garage base alan tomlinson Building & Construction 2 10-28-2008 03:26 PM
