Exposed Crawl Space Insulating Options - Insulation - DIY Chatroom Home Improvement Forum
Old 09-30-2013, 07:55 PM   #1
Rewards Points: 26
exposed crawl space insulating options
I have a room with an exposed crawls space for lack of a better term. The room is built and then the floor was insulated with fiberglass insulation. it is in a cabin type home. And I have replaced it 2X. Seems the squirrils love to use the stuff somewhere else. I have not been able to keep them out long term. Still working on that.
I was thinking of doing spray foam on this. Would that be better and less prone to be removed?
Also what is the difference between the sealant and the insulation, I am looking at the froth packs from home depot.
http://www.homedepot.com/webapp/wcs/...tgry=SearchAll
What would you guys recommend?
blackestate is offline   Reply With Quote
Old 10-03-2013, 11:02 PM   #2
Registered User
Rewards Points: 5,516
Add plywood under the f.b., fig.7; http://www.buildingscience.com/docum...n-crawlspaces/
Gary
Old 10-04-2013, 05:13 AM   #3
Bill Kearney
Rewards Points: 1,174
Originally Posted by Gary in WA View Post
Plywood? That's not what the figure shows, it shows using foil-faced foam board.
wkearney99 is offline   Reply With Quote
Old 10-05-2013, 11:01 AM   #4
Rewards Points: 26
that was a good read. so I have changed because of the expense in doing tat much foam. I now plan to use foam board insulation that is foil backed. steak it 2 to 3 layer deep in the hosts, and seal it with the can foam, and eventually cover the whole thing with the foil backed foam board. I think that I can do this one 2 inch layer at a time.
does that noun like it will work?
Old 10-05-2013, 05:49 PM   #5
Registered User
The plywood is to stop the squirrels from entry. Bottom layer (only) to the joists needs be foil-faced, joints taped, don't forget the rims; http://www.buildingscience.com/docum...l_seal_rev.pdf
Gary
Old 10-05-2013, 06:08 PM   #6
Rewards Points: 1,278
Gary
That sounds just like a bunch of phd educated people. They need to enroll in at least a summer course at an institution that has a squirrelology department.
Insulating my crawl space jimmyfloyd Insulation 2 11-10-2012 04:17 PM
Vapor barrier issue between crawl space and conditioned basement gregsenne Insulation 3 10-11-2012 11:53 PM
Crawl space insulation williamdarrell Insulation 6 10-01-2012 11:08 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 03:11 PM
