Excessive Condensation In Attic - Insulation - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 04:48 PM   #1
Excessive condensation in attic
I just completed insulating the ceilings after My roof was removed by a big blow. I used r-38 12 inch batts-faced.I have noticed a large amount of cond. on the bottom surface of roof(metal) and on the top plates -puddles. The 12 inch inslu.is compacted toward the eves.What I would like to know is when I drywall and seal the joints,will this reduce the amount of cond. I plan to re-roof in the spring . Would I be better off removing the inslu,trimming it down to a thinner thickness.I am better at answering than asking. Any advise will be greatly appreciated
antlerdancer is offline   Reply With Quote
Old 01-04-2012, 06:04 PM   #2
DIY staff
Rewards Points: 7,174
Air must be able to reach the roof through the soffits--and leave the attic through the roof vents.
Do you have soffit vents--and plenty of them?
Can the air flow into the attic or did you block the vents with the insulation?
If so---look for 'insulation baffles' --Plastic things the hold the insulation back so the vents can breath.
Not having the drywall up will allow a lot of extra moisture into the cold attic---so some condensation will occur until that is done----hang some fans up there---and lay plastic over the top of the insulation until you get that buttoned up--
Old 01-05-2012, 08:00 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,606
What is the ventilation like oh'mike said?
Pictures and more descriptions will get you more poignant responses.
Old 01-05-2012, 08:15 AM   #4
Thanks for the responses. The roof I am dealing with is on a mobile home. There are no soffits as the trusses end flush with the outside of the wall.There is one "pot" vent on one end and a gable-end vent,the section is about 40ft.I am hopefull that installing the lids will end the cond.problem.The baffels I installed were supposed to provide space between insul. and roof (steel).Is it a Big problem if they touch? I know that compacting the Inslu.will decrease its R value,but it is better the the 2inches that was in there.Again, Thank You for Your help
Bathroom Fan Vent - Condensation inside duct in the attic lwvargas Kitchen & Bath Remodeling 1 02-24-2011 06:49 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Condensation UNDER insulation in Attic finishing project timsplace Building & Construction 0 01-25-2011 08:11 AM
Attic moisture Carstonio Roofing/Siding 14 01-29-2009 11:35 AM
Condensation In Attic george@DIY Roofing/Siding 3 02-03-2008 10:36 PM
