Exactly How Should I Insulate This? - Insulation - DIY Chatroom Home Improvement Forum
Old 10-12-2012, 12:17 PM   #1
Exactly how should I insulate this?
We are converting a bedroom into a master bath. All of the walls are open. The room is at the north corner of the house on the ground floor. We live in NW Arkansas. The house is a 60's ranch with a full basement. 2x4 walls with brick veneer.
How should we insulate the two outside walls? Pink with paper on one side and facing in? Pink with paper on both sides? In both cases, add a vapor barrier with pink? Or, is fiberglass wrapped in plastic made by Johns Manville a better option? Do it another way altogether?
Also, we would like to insulate a third, interior wall for sound purposes that has the master shower running half the length of the wall with a hallway/guest bath on the other side. Exactly what kind of insulation would you suggest for that? The shower will be tiled.
Thanks in advance.
Honest Bill is offline   Reply With Quote
Old 10-13-2012, 12:05 AM   #2
Registered User
Rewards Points: 526
In Zone 4? http://publicecodes.cyberregs.com/ic..._11_par002.htm
R-13 wall is required; http://publicecodes.cyberregs.com/ic..._11_sec002.htm
No plastic vapor barrier or retarders; http://www.buildingscience.com/docum...commendations/
Gary
How to Vent and Insulate an Enclosed Porch Converted to an Entry Room psubaron Roofing/Siding 14 09-13-2012 08:35 AM
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 03:41 PM
to insulate or not to insulate? tiffertots Building & Construction 0 10-20-2010 11:13 AM
do I need to frame my basement insulate with batt insulation? y2chuck Remodeling 3 02-15-2010 08:13 AM
Insulate or Don't Insulate? helpless handyman Building & Construction 10 03-31-2008 06:07 PM
