Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 09-07-2012, 12:41 PM   #1
Ever encounter asbestos in foam board insulation?
Hello all. New to the forum and happy to start my first thread.
I’m currently removing some 70s looking veneer wall board in my basement and behind it I found styrofoam type insulation glued to the concrete blocks, with random green dots scattered throughout the product. Not sure at this point if the green dots are a result of water/mold contamination from the foam being pressed against the blocks or if it’s actually part of the product and supposed to be there. Anywho, I was explaining what I found to someone and they said I need to be careful about asbestos. The following two pics show what I’m talking about. Has anyone seen this product before and hopefully have some advise?
Thanks!
lilbilly is offline   Reply With Quote
Old 09-07-2012, 12:45 PM   #2
It's not asbestos, but it could very well be mold.
Old 09-07-2012, 12:51 PM   #3
Thanks for the info joecaption, much appreciated. Enjoy the rest of your afternoon.
Chrs!
Old 09-08-2012, 10:35 AM   #4
Exterior Construction
Windows on Wash's Avatar
+1
Much more likely that it is mold than anything else.
Old 09-08-2012, 07:17 PM   #5
Def not asbestos, mold on styrofoam to me
Remod11 is offline   Reply With Quote
Old 09-11-2012, 04:33 PM   #6
gravity always wins
That'd be some mighty funky looking mold. Looks more like something that was splattered on the foam board. Mold would have attacked the studs before the styrofoam because mold would starve on plastic. It's certainly not asbestos.
Old 09-13-2012, 12:57 AM   #7
Moderator
My eyes aren't what they used to be but it appears on the board edge also, in the first photo...did you just remove that missing chunk?
Gary
Clothes taking longer to dry?
Old 09-25-2012, 03:45 PM   #8
Gary
It was removed moments before the picture was taken, and you're correct that it's also on the board edge. After closer inspection the dots appear to be solid and of a slightly different material. Maybe some sort of fire retardant although it's very random and some of the sheets have very little of it. Areas of the basement that show absolutely no signs of moisture also had the same random green dots in the rigid foam. Strange
Everything below and just above grade has been removed down to the studs, upper floor joists, and concrete slab. There have been a few surprises but I think I'm in pretty decent shape. Took possession of the house 2 months ago (my first home) and we're still on budget. It was built in 1965 and I was certainly very curious to see behind the walls, etc. I'm about to post one of my issues soon over in Concrete, Stone & Masonry.
Thanks everyone for the comments.
Air Sealing Subfloor Joist Space - Foam Board? masonbrown Insulation 2 05-06-2012 04:54 PM
Installing foam board around windows ? Arky217 Windows and Doors 3 09-12-2011 05:13 PM
Polystrene (DOW) Rigid Insulation board - fireproof AndrewF Building & Construction 8 11-28-2010 02:17 PM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 05:42 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
