EPS Vs XPS - Insulation - DIY Chatroom Home Improvement Forum
Old 03-19-2014, 08:08 AM   #1
Rewards Points: 326
EPS vs XPS
Hi All,
Is there a preference for one foam board versus the other. There is about a $10 difference (EPS is cheaper). I am planning on using 1.5" x 4' x 8' boards in my basement.
I have read that there are marginally performance differences.
I need 40 boards - is the extra $400 worth it?
Amitabh is offline   Reply With Quote
Old 03-19-2014, 10:33 AM   #2
concretemasonry's Avatar
Rewards Points: 2,626
There is a difference in the insulating value.
XPS is a much better insulator and you may be able use thinner sheets for the same insulation value if you go by the fictitious and theoretical R-value concept promoted and miss-used by the fiberglass industry. - Decreasing the thickness can make some finishing details much easier.
In a basement, the R-value might may not be that critical since you are only trying to insulate from the 55F soil for your area in comparison the bitter cold above grade.
EPS does a good job of making coffee cups and trays for meat cuts in a super market.
Dick
concretemasonry is online now   Reply With Quote
Old 03-19-2014, 03:18 PM   #3
Rewards Points: 326
Dick
thanx - i guess i am going with XPS
Old 03-19-2014, 03:32 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,244
+1 to Concretemasonry's feedback.
XPS is the way to go in terms of basement walls.
Old 03-20-2014, 12:43 AM   #5
Registered User
Rewards Points: 526
Or use both (saving $$$) so long as the XPS is above grade and below to the "freeze line" for your location as in fig.40, also read pages 55-58? here; http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
Gary
