Eco Friendly Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 04-12-2014, 10:19 AM   #1
Rob
Robpo's Avatar
Rewards Points: 826
My wife and I are building a small cottage and would like green insulation in attic and walls. We've used blown in cellulose/green fiber brand before, but would like to use wool or other. So far availability and cost seem limiting. Any options?
Robpo is offline   Reply With Quote
Old 04-12-2014, 01:59 PM   #2
Rewards Points: 6,652
You are not going to be eating or breathing it in. So it really does not matter. The White stuff & Blue Jean insulation will cost more, then just using plain Fiberglass.
Old 04-12-2014, 02:09 PM   #3
Rob
Robpo's Avatar
Rewards Points: 826
Thanks but I am looking for something more environmentally responsible.
Old 04-12-2014, 05:54 PM   #4
There is no such thing.
Old 04-13-2014, 12:54 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,742
What is not environmentally responsible about rock wool, cellulose, or fiberglass (assuming all are non-VOC containing variants)?
What is not environmentally responsible is over spending on denim insulation when you could make the home more efficient with that additional budget and in improvements.
What is the home construction type, exterior finishes, roof type and insulation schedule?
Old 04-13-2014, 01:52 PM   #6
Rob
Robpo's Avatar
Rewards Points: 826
What is the home construction type, exterior finishes, roof type and insulation schedule?[/QUOTE]
Strawbale with cement stucco on exterior and lime plaster on interior-corrugated metal roof and trying to get R-60 in ceiling.
I would go cellulose over denim.
Since you mentioned it, what is rock wool? I always thought it was asbestos
Old 04-13-2014, 01:55 PM   #7
What comes to question. Is what is going to keep the Straw Bales from rotting and end up with millions of fungi spores. Denim is better then Cellulose. You of course already have Cellulose as the wall material.
As for Rock Wool. The old stuff may have contained some Asbestos. Asbestos is still used in products even today. But is encapsulated to prevent it from become Free.
Old 04-13-2014, 02:10 PM   #8
Rob
Robpo's Avatar
Rewards Points: 826
Is what is going to keep the Straw Bales from rotting and end up with millions of fungi spores. I live in NV, We check the moisture when we get them and keep them dry. We don't have cellulose in the walls. So what is rock wool? Anyone know?
Old 04-13-2014, 02:41 PM   #9
Straw as I stated is Cellulose. Rock Wool is exactly that. It is rocks turned into a Wool type substance for Insulation.
If water is ever allowed to penetrate the inside of the walls. The bales start rotting. Looks good on paper, but in the long run not something that will stand the test of time.
Old 04-13-2014, 07:07 PM   #10
No talk of air sealing or anything else?
Why not build a staggered wall construction, air seal all the wall plates and just use a non-voc containing cellulose.
Old 04-13-2014, 07:19 PM   #11
There is also the Soy based Foams Wash.
Old 04-13-2014, 07:56 PM   #12
Rob
Robpo's Avatar
Rewards Points: 826
Plans are already done an approved for strawbale. Plus we live in a strawbale house and love it.
Old 04-14-2014, 09:03 AM   #13
Yes. I know they are marketed as such but there is still a heavy VOC component to any and all onsite SPFs.
If not, you could spray it without PPE and that just isn't the case.
Old 04-14-2014, 09:29 AM   #14
Rob
Robpo's Avatar
Rewards Points: 826
The protection would be as much of a problem as getting a sprayer.
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 06:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
