Drafty Lights - Insulation - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 08:16 AM   #1
Rewards Points: 37
Drafty lights
Hello,
I have a lot of cold air falling from my recessed lights and bath exhaust fans. I can seal around the fixtures with caulking to slow the drafts, but what else do I need to do eliminate the draft from the attic to my living space?
Thanks.
nbmech is offline   Reply With Quote
Old 12-28-2011, 08:43 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
You need to insulate from the attic side.
tcleve4911 is offline   Reply With Quote
Old 12-28-2011, 08:53 AM   #3
the Musigician
DangerMouse's Avatar
Also, you could check the exhaust ends of those ducts to be sure the one-way flap(s) is/are working properly. If they get stuck open, they'll allow a lot of air to move down into your home.
DM
Old 12-28-2011, 09:56 AM   #4
Rewards Points: 13,450
If the wrong llights were installed there going to leak air. They needed to be IC Air Tight. It should say so on the inside of the light if you remove the defuser on under the electrical connection box.
If it not an IC fixture you can start a fire by coving it up with foam or insulation.
Old 12-28-2011, 11:53 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,090
If they are non-IC rated, a box constructed of fire rated gypsum is a great way to seal them up.
If they are in a bathroom, are they in a drop soffit area (i.e. bulkhead)? That is where we commonly see them and that entire drop soffit needs to be isolated out from the attic with some drywall and foam. No need to insulate inside the box once it is sealed off from the home.
Insulate over the top of the enclosed box at that point.
+1 to checking the flappers.
Old 12-28-2011, 12:57 PM   #6
http://www.capri.info/TechTopic/Capri/10.PDF
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 11:45 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
