Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 02-14-2013, 07:03 AM   #1
DOW Styrofoam RM vs Owen Corning F250
I am looking to put 2" XPS against my basement walls (southern NH) and recently started looking at "reclaimed" material. I know I can get new OC F250 from Home Depot for $17.25 per board (2"x2'x8'), but just heard from someone that has reclaimed Dow XPS boards - for $4.40 per board!
The pic provided has DOW Styrofoam in the diamond logo and RM extruded under it to the right.
I think I am looking at an older version of Dow ROOFMATE XPS, the spec sheet shows the same R10 value for 2" XPS. Is there any reason I shouldn't use this in my basement? I plan to put up the XPS and then a drywall in front of it with more R13 insulation. Other than the reclaimed stuff being dirty - is there any issue?
PS. Any thoughts on what I should do on top of my concrete wall where the wires are run?
Basement XPS installation
I am thinking of cutting the top piece of XPS short and using Great Stuff foam to seal the wires in.....
VonTed is offline   Reply With Quote
Old 02-14-2013, 11:17 AM   #2
Architectural Designer
AGWhitehouse's Avatar
Extruded Polystyrene is Extruded Polystyrene...go for it!
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 02-21-2013, 06:54 AM   #3
I pulled the trigger and had it delivered..... and oh my are they filthy. The one pictured above is sparkling clean in comparison.
It there a good, quick way to clean extensive dirt/grime of these things? Can I pressure wash them, or will that harm the material? What about cleaning products, will they soak in to the material or anything like that?
Old 02-21-2013, 09:55 AM   #4
My guess is most of that dirt/dust is clinging on by static. Using a regular garden hose should be sufficient.
House2HomeLLC is offline   Reply With Quote
Old 02-21-2013, 10:06 AM   #5
Yeah, I thought I'd try the non-powered version first
I think I'll it a try this afternoon, it is supposed to be SEVERAL degrees above freezing!
Old 03-25-2013, 06:45 PM   #6
Well it did get much cleaner, but still "dirty" - usable. And I did find a 10% drop out from ruined panels or significant damage. Not sure it was worth the extra work.... but it is installed
Old 03-26-2013, 08:22 AM   #7
Exterior Construction
Windows on Wash's Avatar
It was worth it. For the price you got it and for the fact that you are keeping it out of the landfills.
Good job.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
AGWhitehouse (03-26-2013), Nailbags (03-26-2013)
Owen Corning 50 yr versus GAF lomanu5 Roofing 2 05-16-2012 12:16 PM
Manufacture History Roofmaster417 Roofing 6 02-23-2012 03:40 AM
What kind of adhesive to use on Styrofoam insulation? tripower Building & Construction 9 05-19-2009 09:39 AM
Red Styrofoam pad with stryro foam balls underlayment genner Flooring 4 03-31-2009 11:25 PM
Styrofoam vs. Plastic vent channels dpreznik Roofing 14 05-10-2007 03:58 PM
