-   Insulation (http://www.diychatroom.com/f103/)
-   -   DOW Styrofoam RM vs Owen Corning F250 (http://www.diychatroom.com/f103/dow-styrofoam-rm-vs-owen-corning-f250-171902/)
VonTed 02-14-2013 06:03 AM
I am looking to put 2" XPS against my basement walls (southern NH) and recently started looking at "reclaimed" material. I know I can get new OC F250 from Home Depot for $17.25 per board (2"x2'x8'), but just heard from someone that has reclaimed Dow XPS boards - for $4.40 per board!
The pic provided has DOW Styrofoam in the diamond logo and RM extruded under it to the right.
I think I am looking at an older version of Dow ROOFMATE XPS, the spec sheet shows the same R10 value for 2" XPS. Is there any reason I shouldn't use this in my basement? I plan to put up the XPS and then a drywall in front of it with more R13 insulation. Other than the reclaimed stuff being dirty - is there any issue?
http://i145.photobucket.com/albums/r...psf7f72733.jpg
PS. Any thoughts on what I should do on top of my concrete wall where the wires are run?
http://www.diychatroom.com/f103/base...lation-171248/
I am thinking of cutting the top piece of XPS short and using Great Stuff foam to seal the wires in.....
AGWhitehouse 02-14-2013 10:17 AM
Extruded Polystyrene is Extruded Polystyrene...go for it!
VonTed 02-21-2013 05:54 AM
I pulled the trigger and had it delivered..... and oh my are they filthy. The one pictured above is sparkling clean in comparison.
It there a good, quick way to clean extensive dirt/grime of these things? Can I pressure wash them, or will that harm the material? What about cleaning products, will they soak in to the material or anything like that?
House2HomeLLC 02-21-2013 08:55 AM
My guess is most of that dirt/dust is clinging on by static. Using a regular garden hose should be sufficient.
VonTed 02-21-2013 09:06 AM
Yeah, I thought I'd try the non-powered version first :)
I think I'll it a try this afternoon, it is supposed to be SEVERAL degrees above freezing!
VonTed 03-25-2013 05:45 PM
Well it did get much cleaner, but still "dirty" - usable. And I did find a 10% drop out from ruined panels or significant damage. Not sure it was worth the extra work.... but it is installed :)
Windows on Wash 03-26-2013 07:22 AM
It was worth it. For the price you got it and for the fact that you are keeping it out of the landfills.
Good job.
