Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 03-29-2011, 10:16 PM   #1
Double-wall construction
So, I am planning on building a 1000 sq ft super-insulated cabin, (located in mid-Saskatchewan where it can be very cold), and intend to make the exterior wall a double-wall.
I would like to make the outer wall with 2x8 for R-35 batt insulation which is 8 inches thick, and the inner wall with 2x6 and R-20 batt insulation, and a 2-3 inch air space in between.
Does anyone have any experience building double-wall construction for housing? Where exactly should the vapour barrier be located?
Any help on building a super-insulated home would be greatly appreciated.
wwsteel7 is offline   Reply With Quote
Old 03-29-2011, 11:45 PM   #2
Moderator
I moved you to "Insulation" for better response, if you don't mind.
This will get you started, notice the gaps for convective loops; The "biggest loser" in fiberglass insulation....
Gary
Clothes taking longer to dry?
Insulating between joists with double brick wall. rugby style Building & Construction 3 12-20-2010 03:25 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 05:18 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
