Double Vapour Barrier In Canadian Basement Wall - Insulation - DIY Chatroom Home Improvement Forum
Old 07-28-2014, 06:52 PM   #1
double vapour barrier in Canadian basement wall
I'm in Ottawa (Canada) where it gets super cold in winter. I've started doing some wall repairs in the basement of a 1960's bungalow, and when I took some drywall down, I saw that there was a plastic vapour barrier on both sides of the pink insulation. One layer of poly behind the 2X4 studs, against the concrete foundation wall, and another layer on the front side, behind the drywall. The pink insulation was in effect, encapsulated in plastic. This can't be right. A vapour barrier usually goes on the warm side only. My question is this: should there be anything at all up against the concrete, like tar paper, or whatever? The studs BTW are slightly less than an inch out from the wall, so that's a good thing. I've pulled the inside vapour barrier out. Now I just need to re-do the wall that I've opened up (properly). Thanks in advance.
Buzzman is offline   Reply With Quote
Old 07-29-2014, 04:07 PM   #2
Thread killer
Rewards Points: 272
I use foam on the walls, I've never put anything else between it and the concrete. You'll want get rid of the air gap behind your insulation, sprayed foam is an easy way to accomplish that(unless you want to rip out the studs and start over)
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 07-29-2014, 06:23 PM   #3
Yea, I'd like to use spray foam, but I've only opened up a part of the perimeter wall, not the whole thing. To do spray foam properly, I'd have to rip out all of the drywall in the basement, and that's not happening. I guess I'm just going to re-install the fibreglass batts, and vapour barrier the inside (warm side) only. BTW, why do you suggest eliminating the gap behind the insulation? Thanks.
Old 07-29-2014, 07:39 PM   #4
Thread killer
Rewards Points: 272
If you have an air gap at the cold concrete, you will get convective loops, lowers the R rating on your insulation(more so in fibrous insulation than foam, think density) The air gap usually gets put in to avoid concrete that may get damp touching material that shouldn't get wet(wood, fibrous insulation) If you can use foam, do it. There is some good info here, just look for posts by Gary in WA and Windows on Wash.
Old 07-30-2014, 01:09 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,634
No more good information that this right here Canucker.
You don't want that air space in your case.
You could cut and cobble rigid foam in there if you wanted but the air space isn't a benefit in this case.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Canucker (07-30-2014)
Basement Vapour barrier issue. EasternCanadian Insulation 15 01-26-2013 10:33 AM
Floating wall for basement pattyobrien3 Remodeling 11 11-07-2012 04:58 AM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
vapour barrier on one wall only? hobbs in vanvouver Remodeling 2 05-22-2008 11:21 AM
Double Vapour Barrier? canadaclub Building & Construction 4 01-14-2007 05:42 PM
