Does Spraying Foam On Edges Of Studs Actually Effective At Air Sealing? - Insulation - DIY Chatroom Home Improvement Forum
Old 05-28-2014, 08:09 PM   #1
Rewards Points: 143
Question
Does Spraying Foam on Edges of Studs Actually Effective at Air Sealing?
Hi everyone,
So I have seen online that people use the spray foam in a can and run a line of foam around the perimeter of there stud walls (Part that has the outside plywood) and then put in there fiberglass batts.
Is this actually a smart and effective way of air sealing?
Does Spraying Foam on Edges of Studs Actually  Effective at Air Sealing?-spray-foam-stud-bay.jpg
cloves is online now   Reply With Quote
Old 05-28-2014, 09:27 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
Can be but caulk is probably easier here.
Old 05-29-2014, 04:02 AM   #3
Rewards Points: 243
Yes, use caulk. Save the foam for big gaps.
chemman is offline   Reply With Quote
Old 05-29-2014, 10:42 AM   #4
Rewards Points: 143
the arrow I drew actually just points to the corner but I meant to mark the whole strip. the problem with using caulk in this situation to go up and down the stud Bay is that caulk does not expand that much.
Old 05-29-2014, 12:46 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why would it need to expand? Caulk would be a lot more cost-effective and achieve the same end results.
XXX
Old 05-29-2014, 03:07 PM   #6
Rewards Points: 12,830
There should be no gaps there to fill.
Looks like a waste of time and materials to me.
Not going to do a thing to stop thermal bridging, or stopping the chimney effect inside the wall cavity.
Bud Cline (05-29-2014)
Old 05-29-2014, 09:32 PM   #7
Rewards Points: 110
Waste of time and $$ IMHO. Just finishing up on an energy star certified new home in MA, inspected periodically from the git go by the energy star guy, no caulking, foam, whatever around the studs in the location you show. Yes to California corners. Yes to r-21 walls. Yes to r-38 ceiling, yes to NON-EXPANDING foam around windows and doors. But caulking there, not so much. Ron
ront02769 is offline   Reply With Quote
Old 05-29-2014, 10:12 PM   #8
Rewards Points: 424
Use your time to put the insulation in right with the flanges stapled to the 2x4 edges and seal the drywall at the top plate to prevent cold air from filtering down from the attic, interior walls included.
Old 05-30-2014, 12:35 AM   #9
Rewards Points: 243
I did what the OP is describing. The exterior of my walls are 2' by 8' TG XPS board. The boards were mostly put together in a hurry leaving all kinds of gaps and tons of air intrusion. I caulked all the joints and around the perimeter of the stud bays with Alex Plus and installed rock wool. NO air movement now. Now if the OP's walls are assembled tightly then its probably overkill. Wait for a windy day and feel around with your hand for drafts.
Old 05-30-2014, 12:44 AM   #10
Registered User
Rewards Points: 4,912
Yes, it is a smart way to air seal against infiltration/exfiltration which severely degrades your FG R-value; https://docs.google.com/viewer?a=v&q...M8l_EeA2F-qvvA
It also stops any air movement to the attic (heating climate= warm air rises, no cold air coming down), contributing to the "stack effect"(also seal the wiring holes and ADA the drywall; http://www.wag-aic.org/1999/WAG_99_baker.pdf
http://www.buildingscience.com/docum...wall-approach/
Furnace filters are made of fiberglass- do a great job of air filtering, not blocking air.http://www.buildingscience.com/docum...ty-insulation/
Yes, follow your good plan- page 21, 22; http://www.engr.psu.edu/phrc/trainin...ngbarriers.pdf
Air leaks (through plywood sheathing-stud joint/wire holes/under bottom plate/ around top plates can also be dangerous to your health; http://www.buildingscience.com/docum...and-rot-houses
The batt facing does not require stapling (IF proper framing on-center spacing was used- it will support from studs---- to be an effective vapor retarder- if using as an air barrier instead of drywall, then yes- tape all perimeter); https://docs.google.com/viewer?a=v&q...9yRrrdP1VBztDg
Gary
PS. older houses had solid board sheathing on walls, many gaps. Newer ply/OSB have many gaps/cracks from framing lumber differences (studs are mostly 3-1/2"; plate is big/little from that, leaving a gap as the sheathing moves with seasonal RH changes (hence required gaping of sheets)- it's not a boat....
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
DoItMyselfToo (08-30-2014), Windows on Wash (06-01-2014)
Why not remove kneewall batting and replace with foam board? fdecker Building & Construction 1 10-20-2010 05:46 PM
Replace Flange in basement with Foam? mattoxda Plumbing 1 10-10-2010 05:05 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
Using Foam Insulating Sheathing over Studs wiz561 Building & Construction 4 08-28-2010 10:53 PM
Foam Board on exterior of above grade house Sheldon General DIY Discussions 6 12-08-2009 05:05 PM
